Roborock F25 Series
Roborock F25 Series
Smart, Smooth, Stainless
Roborock F25 Series
roborock australia f25 wet dry vacuum smart one-stroke cleaning for spotless floors roborock australia f25 wet dry vacuum smart one-stroke cleaning for spotless floors
Smart Wet-and-Dry Cleaning
Spotless with a Single Stroke
roborock australia f25 JawScrapers brush technology eliminates tangles for streak-free vacuuming roborock australia f25 JawScrapers brush technology eliminates tangles for streak-free vacuuming
JawScrapers
Complete Clean
roborock australia f25 edge-to-underneath cleaning roborock australia f25 edge-to-underneath cleaning
roborock australia f25 self-cleaning roller roborock australia f25 self-cleaning roller
Stays Clean and Ready to Roll
roborock australia f25 slidetech 2.0 maneuvering roborock australia f25 slidetech 2.0 maneuvering
Seamless and Upgraded
Maneuverability
roborock australia f25 smart vacuum app alerts roborock australia f25 smart vacuum app alerts
Intelligent App and
Voice Alerts
Sticky, Even Hairy Mess?
Make It No Mess.
99.99 %2
Bacteria Removal Rate
99.99 %2
Spend less time cleaning and more time living. With 20,0001 Pa suction and a 450 RPM cleaning frequency, the Roborock F25 Series delivers spotless results in a single stroke.
Cleaning Strokes3 / min
20,000 Pa5
Suction Power
>20 N4
Downward Cleaning Pressure
<1mm
Edge-to-Edge Cleaning9
<1mm
60 min7
Battery Life under Eco Mode
410 sqm8(4,413 sqft)
Cleaning Area per Charge
roborock australia f25 streak-free floor cleaning with tangle-free brush roborock australia f25 streak-free floor cleaning with tangle-free brush
JawScrapers Roller
Designed for Lasting Shine
Tangle Rate10
12.5cm 0°
roborock australia f25 smart sensor adjusts cleaning intensity roborock australia f25 smart sensor adjusts cleaning intensity
DirTect® Smart Sensor
Smarter for Superior Cleaning
Cleaning Level
4 ...
Dirt Level
roborock australia f25 30-day auto-dosing detergent system roborock australia f25 30-day auto-dosing detergent system
Auto Detergent Dispenser
*Available on Roborock F25 ALT and Roborock F25 ACE.
Proactive Self-Washing
As you clean, the F25 series uses the DirTect® module to detect the cleanliness level of the water, so it knows how much it should be self-cleaned, even before it is placed back in the dock. *
Moves as You Move
Small Tweak, Big Improvement
90 °C13
5 min
Fast Drying
99.99 %14
Multiple Stages
Separation System
99.99 %14
Multiple Stages
Separation System
Intuitive to Use,
roborock australia f25 voice alert roborock australia f25 voice alert
Voice Alert
Auto
Cleaning Rollers
Empty the dirty water tank
Auto
Cleaning Rollers
roborock australia f25 screen display for status check roborock australia f25 screen display for status check This is a image
roborock australia f25 one-touch App customization roborock australia f25 one-touch App customization This is a image
One-Touch App Customization*
0 0
Key Specs
roborock australia f25 product image
Roborock F25
Learn More
4.2kg
Dimensions (with dock)
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
roborock australia f25 ACE product image
Roborock F25 ACE
Learn More
Auto Detergent
Dispenser
App Customization
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
Key Specs
Roborock F25
Learn More
Roborock F25 ACE
Learn More
4.2kg
330 * 316 * 1157
Dirty Water Tank
720ml
Clean Water Tank
870 ml
Battery Life 60min
(Eco Mode)
Auto Detergent
Dispenser
App Customization
4.7kg
352 * 316 * 1157
Dirty Water Tank
720ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Battery Life 60min
(Eco Mode)
roborock australia f25 is being used to clean coffee stains in the kitchen
13.Based on internal testing. The self-washing temperature refers to the temperature of the hot air outlet blowing over the water, not the temperature of the water itself. Actual results may vary depending on environmental factors.
