In Open Spaces
Meet Qrevo Edge 2 Flow — an ultra-slim roller mop robot vacuum featuring SpiraFlow™ 2.0 Pressurized Real-Time Self-Cleaning, 35,000 Pa HyperForce® digital motor power¹, tangle-free cleaning, and a brand-new all-in-one dock for effortless maintenance.
One Pass. Truly Fresh.
Built to clean deeper.
Lifts Even the Finest Dust You Can’t See
No hair wrap². Made for pet homes.
Fresh, from start to finish.
SpiraFlow™ 2.0 Pressurized Self-Cleaning System
Specially designed to tackle sticky messes and spills, the upgraded SpiraFlow™ 2.0 uses a pressurized water pump to distribute clean water across the roller through 2× more hydration points⁴. Combined with 240 RPM rotation⁵ and 2.5× more of downward mopping pressure⁶, it delivers a fresher, more consistent clean with every pass.
Bathroom Splashes
Paw Prints & Footprints
Kitchen Messes
Morning Spills
16
240 RPM
High-Speed Rotation⁵
2.5x
Downward Mopping Pressure⁶
Bacteria Removal Rate⁷
Seamless Across Hard Floors and Carpets.
270 mm High-Density Antibacterial Roller⁸
Helps reduce water spots by
30%⁹
Precision water control, tuned to every floor.
Powered by AI RGB recognition, the robot intelligently identifies different floor types and automatically adjusts water flow for more effective mopping. On wood floors, it optimizes water usage to help reduce streaking.
*This function must be manually enabled in the Roborock app.
Automatic Roller Shield
0 Drips
True Wet/Dry Seperation¹⁰.
15 mm
Max Roller Mop Lift¹¹.
Success Rate
In Open Spaces
Under Furniture
Automatically retracts with a 100° rear view-cleaning tight spaces with accuracy.
35,000 Pa
Max Digital Motor Power¹
Hair Pick-up Rate on Floor¹³
15% Higher
Pet Hair Pick-up Rate¹⁴
The Reversible Side Brush sweeps debris out from corners, while the Edge-Adaptive Roller Mop extends to clean closer to edges, helping cover walls, furniture corners, and skirting boards with less effort.
30% increase
Corner Coverage¹⁵
Edge Sweeping¹⁶
< 10 mm
Edge-Close Mopping¹⁷
Up to 44 mm
Extended Capability¹⁸
Hair Tangling Rate²
Hair Tangling Rate²
Easy-Rinse Dirty Water Tank
The redesigned dirty water tank features a simplified internal structure for easier rinsing, helping reduce residue buildup. An upgraded handle makes emptying more effortless.
75° Tiltable Roller
Tilts up to 75° for easier roller removal and deep cleaning.
280+ Types
of Recognizable Obstacles¹⁹
Stain-Target AI Cleaning
The robot detects stain types through its RGB camera and automatically adapts its cleaning strategy, boosting suction for coffee powder and cat litter, or switching to mop-only mode for liquid spills.
For Wet Messes
For Dry Debris
Your Privacy, Our Priority
Fresh, from Start to Finish.
Multifunctional Dock
The all-new system continuously jets clean water from the dock to refresh the roller, while dirty water is collected separately in the robot’s dirty water tank. With minimal water remaining in the cleaning tray, clean and dirty water stay separated—helping each mop wash stay cleaner, fresher, and more hygienic.
10%
Less water usage²⁰
Roborock APP
The Brain Behind Every Clean
Carpet Cleaning
Want to deep clean carpets or skip them entirely? One tap is all it takes. Your robot adapts automatically—boosting suction on carpets with the mop lifted, or following precise edge-cleaning paths to avoid rugs and keep them dry*. You're in control of every room, every rug, every time²³.
*These carpet cleaning settings must be manually enabled in the Roborock app.
Roborock SmartPlan™ 3.0
One Tap. Let Smart Take Over.
Roborock SmartPlan™ 3.0 automatically recognizes room types, learns your cleaning habits, and selects the optimal cleaning strategy—boosting suction when needed, rewashing the mop as required, and reducing power to minimize noise during Do-Not-Disturb periods.
Pet-Friendly Intelligence
Closer to Your Furry Friends
Automatic Pet Recognition
Pet Snaps
Track Your Pet
Video Call & Cruise
Everyday Features
Key Specs
Qrevo Edge 2 Flow
Qrevo Edge 2 Flow
Qrevo Edge 2 Flow
352*353*89.8 mm
402*470*451 mm
2. Based on internal testing, the hair tangling rate is 0% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively under controlled testing conditions. Actual performance may vary depending on environmental conditions.
3. Based on internal testing carried out by the manufacturer, the roller mop achieved up to a 100% removal rate of coffee spills, soy sauce, ketchup, and wet muddy spots in a single pass. Actual results may vary depending on environmental conditions.
4. Compared to SpiraFlow 1.0 with 8 hydration points. Based on internal manufacturer testing. Actual results may vary depending on environmental conditions.
5. Based on internal testing carried out by the manufacturer, when selecting the Extreme Water Flow setting in Custom Mode, the mop can spin at a maximum speed of 240 RPM. Actual results may vary depending on environmental factors.
6. Compared to the Roborock Qrevo Curv, which delivers up to 6 N of mopping pressure, the current model delivers up to 15 N, based on internal testing conducted by the manufacturer. Actual performance may vary depending on home environments.
7. Based on testing carried out by TÜV SÜD, over 99.99% of Escherichia coli, Staphylococcus aureus, and Candida albicans on the roller mop is effectively removed. Certification No. 704012602394-00. Actual results may vary according to the home environment.
8. Tested by SGS in accordance with GB 21551.2-2024 Antibacterial and Cleaning Function for Household Appliances, the antibacterial rate against Klebsiella pneumoniae ATCC4352 reached over 99.99% (Test Report No. ASH26-0017316-01A1). Actual results may vary depending on the home environment.
9. Compared to the performance of Qrevo Curv 2 Flow. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
12. The robot vacuum has a body height of 8.98 cm. Due to slight vertical flexibility in the front structural components, it may achieve limited passive compression when entering low-clearance spaces, allowing access down to 8.98 cm. However, scraping may occur. Actual performance may vary depending on environmental conditions.
13. Based on internal testing, the hair removal rate 100% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively under controlled testing conditions. Actual performance may vary depending on environmental conditions.
14. Compared to the performance of Qrevo Curv. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
15. Compared to the corner coverage performance of Qrevo Curv 2 Flow. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
16. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
18. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
19. Based on internal testing carried out by the manufacturer, the robot vacuum can detect and bypass objects as small as 3 cm wide and 3 cm tall. Recognition accuracy may vary depending on environmental factors.
20. Compared to the water usage of Qrevo Curv 2 Flow under Soaking Mode. Actual results may vary depending on environmental factors.
21. Based on internal testing carried out by the manufacturer, the internal heating module during drying can reach up to 63°C under standard room temperature conditions. Actual temperatures may vary due to environmental factors.
22. Based on internal testing carried out by the manufacturer. Actual emptying intervals will depend on usage habits and environmental factors.
23. This feature is applicable to household carpets with pile heights of 3 cm or below, covering the majority of carpets used in typical homes.
