HyperForce® Suction Power 1
10,000 Pa
HyperForce® Suction
Dual Anti-Tangle System
Auto Lifting Mopping
System
ReactiveTech Obstacle
Avoidance
PreciSense® LiDAR
Navigation
Self-Emptying Dock
Flexible App Control
Impressive HyperForce® Suction Power
Root Out Hair From
Crevices and Carpets
Suction Power
Root Out Hair
From Crevices and Carpets
JawScrapers Comb
Anti-Tangle Main Brush
Hair Tangling on Side Brush 2
The Auto-Lifting Mopping System automatically adjusts to carpets, providing a thorough clean with ease. Enjoy efficient, effortless mopping for consistently spotless results.
8mm
Mopping Module Lifting3
Powered by structured light, this advanced system effortlessly detects and navigates around obstacles, even in cluttered rooms with items scattered across the floor.4
Experience hassle-free cleaning convenience with the RockDock Plus. The large dust bag lets you clean for up to 7-10 weeks without emptying5, making it ideal for families with pets and reducing allergens.6
Temporary Cleaning
Auto Boost on Carpet
High-Intensity Mopping
Cleans Along Floor Direction
Robot Vacuum
2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN251UKF 001. The pet hair anti-tangle rate is 0%, while short human hair (20 cm) anti-tangle rate is 0.063%. Actual results may vary depending on usage conditions.
4. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
