10,000 Pa
HyperForce Suction
8,000 Pa
HyperForce Suction
Roborock Q7T(+)
Roborock Q7B(+)
Dual Anti-Tangle System
Three Levels of
Water Flow
PreciSense LiDAR
Navigation
Self-Emptying Dock
Flexible App Control
Impressive HyperForce
Suction Power
Root Out Hair
From Crevices and Carpets
Roborock Q7T(+)
HyperForce Suction Power 1
Roborock Q7B(+)
With an impressive 8,000 Pa suction, this powerful system is built to lift hair and debris from floor crevices and deep within carpets.
JawScrapers Comb
Anti-Tangle Main Brush
Hair Tangling on Side Brush 2
Consistent Water
Flow Mopping
3 Levels
Water Flow Options
Detachable Mop Design
For Versatile Cleaning Needs
Anti Scale Design
Built-in nonhazardous4 descalers bag prevent scale formation and protect pipes from clogging for up to 3 years5.
Roborock Q7B(+)
Roborock Q7T+
Roborock Q7B(+)
Roborock Q7T+
Experience hassle-free cleaning convenience with the RockDock Plus. The large dust bag lets you clean for up to 7-9 weeks without emptying6, making it ideal for families with pets and reducing allergens.7
Temporary Cleaning
During cleaning, if any area is not properly cleaned, you can direct the robot to clean it again. Once finished, it will resume its original task.8
Auto Boost on Carpet
Automatically detects or sets carpet areas, increasing suction power for deeper cleaning and enhanced dirt removal, ensuring a fresher, cleaner home.8
High-Intensity Mopping
In DEEP mopping mode, movements slow down, and mopping paths are finely divided for a deep, thorough clean, helping to tackle stubborn dirt with enhanced slow-mop action.8
Cleans Along Floor Direction
Cleans along the direction of preset tiles for improved hair and dust removal from crevices while reducing noise from the main brush rubbing against floor cracks.8
Robot Vacuum
2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN25I41V 001. The pet hair tangle rate is 0%, while short human hair tangle rate is 0.063% Actual results may vary depending on usage conditions.
4. Based on SGS testing and the Safety Data Sheet, the integrated FOF scale inhibition filter material is biologically inert and environmentally compliant.Under normal usage conditions, it presents no viable pathways for accidental ingestion, dermal contact, or ocular exposure. Water processed through the FOF system contains no detectable chemical contaminants. Actual performance may vary depending on environmental conditions.
5. Based on internal testing by the manufacturer, after simulating three-year usage of the product, the scale inhibition rate is higher than 91.7%. Actual performance may vary depending on environmental conditions and usage conditions.
6. Based on Roborock internal testing. Actual performance may vary depending on home environment, cleanliness level, user habits, and other factors.
7. Based on testing carried out by SGS according to PT-22-000-100650 and PT-22-000-401140 standards, the dustbag filtration rate of mulberry pollen, cat allergen, dog allergen and dust mites allergen is more than 98.1%. Actual results may vary depending on usage conditions.
8. Some features will be available via an upcoming OTA software update for certain models. Actual performance may vary depending on usage conditions and software updates.
