roborock qrevo c vacuum cleaner official australia roborock qrevo c vacuum cleaner official australia
Roborock Qrevo C
Meet your new cleaning powerhouse - the Roborock Qrevo C. Designed to blend seamlessly into your daily routine, it boasts the Dual Anti-tangle system and impressive 12000 Pa suction1, making hair tangles a thing of the past. Paired with the Multifunctional Dock, obstacle avoidance system and convenient App Control, keeping your home tidy is a breeze.
Zero Wraps. Double Guard.
DuoDivide® Main Brush
Hair tangles? No worries. Equipped with two parallel short bristle rollers and spiral blades, the DuoDivide® Brush works in harmony to deftly direct hair toward the central dustbin inlet. It prevents tangles and clogging, ensuring that your floors are left impeccably clean without hair.
qrevo c DuoDivide® main brush roborock australia
qrevo c 0 hair Tangling roborock official australia
Hair Tangling3
Hair Removal4 This is a image
Anti-Tangle Side Brush
roborock official australia qrevo c anti-tangle side brush
roborock official australia qrevo c  0 hair Tangling
Hair Tangling5
12000Pa HyperForce® Suction1
Deep Clean, Effortlessly
roborock qrevo c 12000Pa HyperForce® suction
HyperForce® Suction
Experience this veritable cleaning powerhouse with its 12000Pa HyperForce® suction. Whether it's hard floors or carpets, it proficiently extracts deeply embedded dirt and dust, guaranteeing a spotless clean with every use.
FlexiArm Edge Mopping
Extend, Mop, and Conquer
1.85mm
Along the Edge6
98.80%
Edge Coverage6
roborock official australia qrevo c FlexiArm edge mopping
Dual Spinning Mops
Mop Like a Pro
roborock qrevo c rotating speed
200RPM
Maximum Rotating Speed7
10mm
Mop Lifting8
roborock qrevo c mop lifting
roborock qrevo c water flow options
30 Levels of
Water Flow Options
See, Sense, and Steer Clear
roborock qrevo c reactive tech obstacle avoidance roborock qrevo c reactive tech obstacle avoidance
Hands-Off, Hassle-Free
Mop Self-Washing
Warm Air Drying
Auto Tank Refilling
Detachable Dock Base
30% Faster Charging9 &
Off-Peak Charging
roborock qrevo c multifunctional dock roborock qrevo c multifunctional dock
Mop Self-Washing
self-washing mop roborock qrevo c official australia
3-Stage
Dynamic Cleaning Process
Warm Air Drying
roborock qrevo c warm air drying feature
45°C
Warm Air10
45dB
Low Drying Noise11
The dock’s dust bag automatically empties the robot’s dustbin, letting you go up to 65 days without manual emptying, giving you long-term convenience.
roborock qrevo c auto dust emptying
65 Days
without Manual Emptying12
99.90%
Pollen Filtration Rate13
roborock qrevo c auto dustbin emptying
Tap. Tap. Clean2
roborock qrevo c app control
Roborock SmartPlan®
Powered by AI, the Roborock SmartPlan® is a game-changer. With just a tap on the App, you can relax and let the robot take over. Based on the analyzed environment, it will automatically determine the optimal cleaning sequence and method.
Temporary Cleaning
Custom Routines
Broadly Compatible with
Third-Party Voice
Control Supported
Fully charged
After Meals
Launcher Widgets
Apple Watch
Roborock Qrevo C
350*353*96.5mm
340*487*519mm
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021 / 5.11 standards, using Max+ mode with a full battery, the maximum suction power can be up to 12,000 Pa. Actual results may vary due to environmental factors. Suction power values may vary by country or region.
9. Compared to the Roborock Q7 Max. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
10.Based on internal testing carried out by the manufacturer, the air temperature around the mop can be heated up to 45°C during drying under 25°C room temperature. The actual results may vary according to the home environment.
11.Based on internal testing carried out by the manufacturer, the noise level when drying is as low as 45dB in a semi-anechoic chamber. Actual noise levels may vary due to environmental factors.
12.Based on Roborock internal testing. Actual performance may vary depending on home environment, cleanliness level, user habits, and other factors.
13.Certification No.PT/23/GEN/0046 by SGS. Actual results may vary depending on usage conditions.
